- Joined
- Mar 5, 2017
- Messages
- 60
- Reactions
- 7
- Age
- 54
Is the Alientech powered? What is the strongest one for the Mavic 2?
Just boost your existing Raptor XR.I just picked up a Raptor XR & had installed but I do not notice a significant difference in range in my residential area... Someone mentioned a powered range extender that is the best one to use.. But no one can tell me the name of it or where to order it.. Any help would be appreciated! View attachment 95824
Get two of these and a little power bank and it will increase your range substantially. Raptor XR is just an antenna, a really good one but still just an antenna.
A powered purpose built range extender is just an antenna (which you already have) and two amps probably not as good as these tucked in a housing with a battery pack built in. It might look prettier but no more functional and you’d be buying a component again that you again already own one of the nicer ones.
Sunhans eSunRC 5.8GHz 2000mW 33dBm Extender Compatible with DJI RC Drones
Amazon.com: Sunhans eSunRC 5.8GHz 2000mW 33dBm Wireless Signal Booster WIFI Amplifier Repeater Extender Compatible with DJI RC Drones Yuneec, UAV, Holy Stone, Potensic and More Other Drones: Computers & Accessories
Amazon.com: Sunhans eSunRC 5.8GHz 2000mW 33dBm Wireless Signal Booster WIFI Amplifier Repeater Extender Compatible with DJI RC Drones Yuneec, UAV, Holy Stone, Potensic and More Other Drones: Computers & Accessorieswww.amazon.com
No you need two of those and the power comes from the USB power bank like this oneInteresting, so just one of these? where does the power come from? what else do i need so i have all components?
Two Sunhans 5.8 boosters. One battery that has two ports that support 2A charging like the one I showed you above. You could use two batteries but that would be unnecessary amount of weight.So should buy 2 Sunhans eSunRC 5.8GHz boosters & hook one up per antenna port? Then the 2 batteries which will power the boosters? Any other wires or connectors required or do they come with the boosters? Is hookup easy?
This would be a good option too. Looks like it’s out of stock and I would probably rather boost on 5.8 than 2.4 but this is a good option and yes it would look better.By the time you have bought the 2 sunhans and the battery and worked out how to mount it
It might be the same price to get a boosted solution using your 4hawks in a nicer form factor
Online Store | titandronesinc
www.commandcase.com
The sunhans are 5.8ghz while the Command Case solution is 2.4ghz. 2.4ghz will give the longer range in principle
It’s always hard to say the range increase but you could realistically expect on the order of 50% to 100% better range.Wow ok thank you! Sounds like something I can setup easily.. I will order the 2 boosters & the battery... That being said, what type of range might this add in a residential area & how long will the battery last on average? Thanks
The 5.8ghz setup would be stronger plus yes the command case is out of stock... It's a decent option but I believe it's pricier... For the setup we were discussing I was probably going to order.. I was thinking of securing the battery & both boosters on the back of the 4hawks with velcro... Will the battery last a few flights powering those dual transmitters?
Yep that’ll work.I was thinking of securing the battery & both boosters on the back of the 4hawks with velcro
Yes. In fact the battery pack I linked above will last many many flights before needing to recharged. Sunhans boosters are very efficient.Will the battery last a few flights powering those dual transmitters?
