Another new to the forums.
DirtyDrone
USA
Hi, figured I’d post here so my first post isn’t about my question!
Been lurking on and off for a going on a year so I figured I sign up and bug you guys.
Lots of good info and the guys that decipher the flight data for lost rigs / issues are impressive!
I have had my air 2S for going on a year and it has been a predominantly reliable and impressive drone, it makes me want a higher end unit at some point.
Greetings from Birmingham Alabama USA, welcome to the forum!
Been lurking on and off for a going on a year so I figured I sign up and bug you guys. I have had my air 2S
As a somewhat New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in the USA, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . 👍
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Reactions: LoudThunder
bobsuruncle
