Dji Mavic 2 Zoom Gimbal Broken
Londonalex
London
Hi All!
New to the group and unfortunately I come bearing bad news. I was pushing my luck with my dji zoom and now I have a warning saying “gimball motor load to large” and “gimball obstructed”.
The gimball almost rotates a full 360 but then stops on its final stages before being centre again. I do still have a clear image but you can feel the gimball is almost stiff when it gets to that side.
any help would be greatly appreciated! I only wish I had taken out the dji care!
what do you mean by pushing your luck.
Did you have an incident? Any further information would be helpful.
I dont owm the zoom, but iimagine it turning nearly 360 is certainly not something that is normal
Reactions: Bobvt
My cat jumped at the drone and it crashed. Now the gimbal does not fully calibrate and shows these warning signs ?
ouch.. Maybe start with checking all of the mounts are still attached correctly, then check the ribbon cables. If everything seems to be connected correctly, then it might be a bigger issue
It’s sucks! I have lost all ability to roll the camera from the remote and it won’t calibrate. Going to try my best to see if I can find any help on this forum ?
wang
