FNG from North Richland Hills, TX
BeBeep
NRH, TX
I am a retired A&P Mechanic/FAA Inspector and a recent Part 107 graduate. I have been wanting a drone for quite some time and finally pulled the trigger on an Air 2S. I have been flying basically daily trying to gain experience. I will mostly be flying for fun but will occasionally take pics and video for my wife’s Real Estate listings.
Hoping to find some better areas around me to fly as flying around my neighborhood is getting kinda old. 😄
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in Texas, there are a couple of Legal Things you may need to do…
You know you'll have to register your Drone…
Link to the FAADroneZone (Optional for Drones under 250-Grams… But not for you…)
Since you live in Texas, there are specific laws and rules for you to follow, please check to ensure these are current.
Since this is your first drone, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: BeBeep
Thank you so much for all the advice and info. I have watched dozens of YouTube videos and I have learned so much from them. I also have a checklist I use which lists the items you noted to perform prior to actually flying.
BTW, I was in the Air Force from 1980 thru 1992. I was a Crew Chief on F-4s and A-10s. Definitely had a blast back in those days.
When I first entered the AF, I was Jet Engine Mechanic at Luke, AZ. We had F-100s then we got the F-4 Phantoms in… Luke was an upgrade pilot base and from there, the pilots almost all went to SEA. I was in Unscheduled Maintenance, that meant we pulled a lot of engines because those guys claimed the Phantom had no "ground effect" when landing and they always hit the runway hard enough to crunch the gear and caused us to pull the engines to see if they had crushed any engine bearings… My last duty station was Davis-Monthan, also in Arizona… and the base flew A-10s there. But by then, I was a computer programmer, systems analysis, and network manager, and long off the flight line…
Reactions: BeBeep
I really loved working the Phantoms, they were a jet you loved to hate. 😀. I was at DM when I crewed A-10s, my wife and I really loved Tucson and the base.
Reactions: LoudThunder
You seem to have such great memories, why did you get out at 12?
Reactions: BeBeep
Hello from the Crossroads of America BeBeep.
Welcome to the Forum. :cool:
Welcome to the forum! :)
My first 10 years was great but then so much started changing (not for the better IMO) when General McPeak took over and it was not the same. I stayed around for 2 more years and then decided to pull chocks and see what civilian aviation was like. Initially it was a culture shock but I actually did really well and it eventually led me to the FAA. I was able to “buy back” my 12 years of military and was able to retire in 2019 with 34 years and 7 months.
I still miss the folks I worked with in the USAF, I keep in touch with many of them. One thing I was never able to experience in the civilian world was the brotherhood and bonds I had in the Air Force. I was 17 when I joined and it helped me learn discipline, gave me lifelong friendships, and taught me a skill that was transferable to the civilian world. I will be forever grateful to the USAF, the NCOs, Senior NCOs and Officers that molded me over the years. 🇺🇸
Greetings from Birmingham Alabama, welcome to the forum!
Hello FNG! I'm in Denton and also a new pilot, but I frequent Angelo Hobbies in NRH. Know that the Texas law regulating drone use, Section 423, was largely found unconstitutional back in March. But NOT the section which pretty much bans any local laws restricting drones. The laws have to be at the state level. I suspect the Houston laws on drone use in parks would not stand up to legal scrutiny.
When it cools off a bit let's get together. Maybe by then I'll have some flight locations to share with you!
Reactions: BeBeep and GFields
JefScot
