If your Mavic falls out of the sky...
Good info and thanks for sharing. May be if you post the serial# of the battery, others with the same batch may consider buying new ones - hopefully with better soldering
Do we need to start opening our batteries and glueing the terminal. Or do dji need to do a recall like Car company’s do????
Cart before the horse. We have no idea if even a single crash has been caused by this yet.
OK I'm just wondering on how you check each cell for voltage? I'm not having any problems other than signal loss but I think this may be important to check out every once in a while. thanks
As mentioned Go4 but also if you fly Litchi you can subscribe for free to Airdata UAV and it gives a great battery breakdown per cell including anomalies.
That one the battery dropped to half and the conclusion is conjecture:
It would seem that reason for the abrupt power loss is either a battery that wasn't seated properly or a battery failure. The .DAT can't really distinguish between these.
I would submit that dropping to half is NOT what would happen with a terminal failure or a battery popping loose. It really is an all or nothing proposition.
Actually this sounds familiar to another case on this forum. DJI, IIRC, replaced it under warranty. The drone was hovering then fell down while still powered on. The owner created a video to demonstrate the failure. When we looked at the logs, some aspects of the abruptly stopped recording new value and froze. The internal computer crashed mid-flight. @BudWalker remember that one?
But when it was falling the motors were spinning and leds were on, when it was falling it was upright and not tumbling, and props were spinning cause if they weren't the drone would be tumbling and fast this was kinda like landing very fast
How can you tell if the voltage drop happened BEFORE it hit the ground?
The file stops abruptly before it even started falling, it flew 50 more feet after the file stopped, then fell
In the case I described above, I speculated to the possibility to a final FINAL failsafe of the drone. In the event of a total system failure, the power is cut to the propellors after a few seconds of timing out.
Not sure same issue. Like when quoting teh bible - context matters.
I can certainly look if I haven't tossed the carcass yet. Good idea.
No, you're not reading correctly. This is the graph of what it looks like when the battery pops out of the drone or there is some kind of battery failure where all power from the battery is immediately lost. The motor volts drop slowly rather than instantly to 0, as they drain the capacitors.
Reactions: sar104
It doesn't just drop to half - but when it gets below that value the logging stops because the FC shuts down.
Just go and test it if you really doubt the explanation.
There are no capacitors of sufficient capacity to retain voltage for any significant time. Those motors draw amperes of current.
Best guess from the experts is that the Mavic motors draw around 12 amps each.
R = V/I = 1 ohm resistance.
Voltage across the capacitor - we'll use half since that is the data file value - is the formula
Vc is the voltage across the capacitor, Vs is the source (12 V), t is the time in seconds, RC is the time constant of the resistor capacitor combination.
So the motor resistance is 1 ohm - let's assume the time from the graph is 20ms which is the time interval of logging (1/50 Hz)
A 1000 uf capacitor (.001 farad) would be a very large one for the circuit board so the resulting time constant with the motor is .001.
Solving for t as a value to result in half the supply voltage of 12 = 6 v gives us .0007 s as the time needed to discharge the capacitor to 6 volts.
I think we can agree that 7 ten thousands of a second is far far less than the 20 ms sample time - it's nowhere near fast enough to detect.
if you wanted to solve for having 6 volts at the end of the 20 ms sample window the necessary capacitor would be .02 farad - a physically huge capacitor that would likely be bigger than the battery.
So I stand by my assertion in that there's no capacitor large enough to keep the motors running for anywhere near 20ms.
Nice analysis, but you are assuming a purely resistive load. In this case the load is highly inductive and you have not taken into account inductively stored energy which may account for the difference. Time for an experiment - I'll do it if you are not planning to.
Reactions: f3honda4me
Since about two DJI AC "updates" ago AirData has been unable to pull specific data for individual batteries, instead lumping all as "Default Mavic Pro Battery". This was a very valuable feature for me, have you found a way to keep track now? (Sorry for the hijack...)
Nope - sorry but if the motor draws that much juice it appears as that load resistively since it is the ESC that is the load - not the motors. The ESC's converts the DC into stepped phases to drive the stepper motors.
I'd hope that you could see there's simply no way that much capacitance is in the system but as usual y'all prefer to argue about pet theories even when I show the maths.
(edited to correct EMF to ESC - lol, EMF is the inductive backlash from a collapsing inductive field)
Hmmm - mine still shows the individual cell data and battery metrics. I just screen captured this to make sure.
Note that this is under flight information->power tab, not the batteries which is a premium feature.
Reactions: Callum
Nope - sorry but if the motor draws that much juice it appears as that load resistively since it is the EMF that is the load - not the motors. The EMF converts the DC into stepped phases to drive the stepper motors.
In my opinion your maths is too simplistic and based on assertions about the nature of the load to be regarded as definitive. You may still be correct, which of course leaves the previously observed data as a bit of a puzzle, but we'll find out soon enough by testing. I suggest we reconvene once we have some good data to look at.
Reactions: Callum
Yes it is simple but it's a standard technique in blackbox analysis to reduce complexity to simple to analyze forms.
At it's core the ESC is a resistive load since it consumes current. The fact that it transforms the current into another form to be delivered to a reactive load is immaterial since the load is isolated and we only care about and measure the current being consumed.
Before you guys get too far off in the weeds. Looking at the motorVolts has proven to be a good way to determine if either the battery came loose or there was a battery failure.
Reactions: sar104
Agreed, but it does not always follow that a simplification is correct. Remember that the voltages that we are talking about monitoring here are the voltages at the motor (those are the ones that are sampled at 50 Hz - not the battery voltages directly which are only 1 Hz), so they are in the inductive side of the circuit where the inductively stored energy is available.
I agree, but given that, we should still be able figure out that enough energy is stored to permit that to happen. I cannot criticize @Brojon for wanting to verify that.
Excuse my ignorance but going to throw something in and you can correct me if I'm way off the mark.
Am I right in thinking the mavic motors are vector controlled AC motors?
I usually work with 20kw+ induction motors and when power is lost the voltage decays and shifts a phase as it coasts to a stop.
Could this decay in motor voltage explain the drop you see?
I wouldn't think so since the voltage is converted into pseudo sinusoidal waveforms for the motor windings. The drivers are usually high power stepper driver chips containing power MOSFETs which will suppress any EMF from the motors. The chips have feedback (usually via serial) corresponding to the integral of the power delivered - not the actual voltage since it varies by a sine approximation.
Here's a good overview of a typical ESC.
genoavoles
