Lost drone after 3 days..
so as of now, recreational fliers can legally fly above 400', thanks.
That's correct. You still must fly within VLOS though.
That section is quite loosly worded.
I still stand on if it can logistically be enforced as things are, then they might just do that.
No policy change needed to enforce 400ft law. Its law or it isn't. There's no 336 anymore (it is repealed) to contradict it.
As a matter of fact, FAA had been trying to impose this limitation in its policies while fitting into 336. Now with no 336 to impede them, their policies are enforceable.
Now the test requirement is different. No such test is yet defined.
Also the means of obtaining authorization isn't yet clear in many cases.
There is no ambiguity:
a) Regulations.--Notwithstanding the repeals under sections 341,​
348, 347, and 383 of this Act, all orders, determinations, rules,
regulations, permits, grants, and contracts, which have been issued
under any law described under subsection (b) of this section before the
effective date of this Act shall continue in effect until modified or
revoked by the Secretary of Transportation, acting through the
Administrator of the Federal Aviation Administration, as applicable, by
a court of competent jurisdiction, or by operation of law other than
this Act.
The relevant regulations are codified in 14 CFR, and that is what will be modified as described here. It has not yet happened.
Reactions: msinger
this Act.
That said - I just noticed that subsection (b) does not mention Section 336 - only 332, 333 and 334. That seems like it must be an omission, since they cannot just leave 14 CFR Part 101 subpart E in limbo.
Where's subsection b?
Section 380 (b):
(b) Laws Described.--The laws described under this subsection are​
as follows:​
(1) Section 332 of the FAA Modernization and Reform Act of 2012​
(49 U.S.C. 40101 note).​
(2) Section 333 of the FAA Modernization and Reform Act of 2012​
(3) Section 334 of the FAA Modernization and Reform Act of 2012​
(4) Section 2206 of the FAA Extension, Safety, and Security Act​
of 2016 (Public Law 114-190; 130 Stat. 615).​
(c) Effect on Pending Proceedings.--This Act shall not affect​
administrative or judicial proceedings pending on the effective date of​
this Act.​
Reactions: sar104
If you want to see everything, search for "SEC. 380. TRANSITION LANGUAGE" in this document.
Correct. Here is the entire Section 380:
SEC. 380. TRANSITION LANGUAGE.
(a) Regulations.—Notwithstanding the repeals under sections 341, 348, 347, and 383 of this Act, all orders, determinations, rules, regulations, permits, grants, and contracts, which have been issued under any law described under subsection (b) of this section before the effective date of this Act shall continue in effect until modified or revoked by the Secretary of Transportation, acting through the Administrator of the Federal Aviation Administration, as applicable, by a court of competent jurisdiction, or by operation of law other than this Act.
(b) Laws Described.—The laws described under this subsection are as follows:
(1) Section 332 of the FAA Modernization and Reform Act of 2012 (49 U.S.C. 40101 note).
(2) Section 333 of the FAA Modernization and Reform Act of 2012 (49 U.S.C. 40101 note).
(3) Section 334 of the FAA Modernization and Reform Act of 2012 (49 U.S.C. 40101 note).
(4) Section 2206 of the FAA Extension, Safety, and Security Act of 2016 (Public Law 114–190; 130 Stat. 615).
(c) Effect On Pending Proceedings.—This Act shall not affect administrative or judicial proceedings pending on the effective date of this Act.
The FAA also has this note posted at the bottom of a few of their registration-related pages (like this one):
"*Section 336 was repealed by the FAA Reauthorization Act of 2018. Changes are forthcoming in 2019 and will be updated here. In the meantime, please follow former guidelines."
Reactions: sar104
fharrihill
