It is okay to recharge a half-charged battery.Hi guys, I was wondering if it is OK to recharge your half flat batteries, or is it better to run them flat before recharging ? What is best for the batteries life ?
Many thanksYes, you can charge them from 50% safely, the will record a half cycle.
If fact, unless you flew that day down to 50% and then wanted to fly a bit more, you really SHOULD recharge and not fly it.
The cells might need rebalancing if it's been left a day or two, or more.
Charging balances the battery cells for longevity.
There's loads of great battery health threads on this forum, but the essential thing is not to leave them fully charged (normally they discharge automatically anyway), don't take off without a recently fully charged battery, and don't fly down to less than say 20% regularly, certainly not less than 10% is good too.
Let them cool to recharge.
That's easy for you to say!Cześć, co zrobisz, jeśli nie leciałeś przez dwa tygodnie i nagle w pobliżu jest fantastyczne wydarzenie, które warto uchwycić z drona. Co podłączasz akumulatory żeby były w pełni naładowane i tracisz cenne ujęcia, czy lecisz z do połowy naładowaną baterią, co zrobisz w takiej sytuacji?
Hi, what will you do if you haven't flown for two weeks and suddenly there's a fantastic event nearby that's worth capturing from a drone. What do you connect the batteries so that they are fully charged and you lose valuable shots, or do you fly with a half-charged battery, what will you do in such a situation?
I would charge them fully as late as possible for you the day before. They will lose little if any charge before you fly them.Cześć, co zrobisz, jeśli nie leciałeś przez dwa tygodnie i nagle w pobliżu jest fantastyczne wydarzenie, które warto uchwycić z drona. Co podłączasz akumulatory żeby były w pełni naładowane i tracisz cenne ujęcia, czy lecisz z do połowy naładowaną baterią, co zrobisz w takiej sytuacji?
