Virtual Litchi Mission
Can someone please find Namirda !!!! (laugh)
Hi everybody! Sorry for going AWOL.
For some reason the Mavicpilots forum software no longer alerts me when there are updates to this thread - I don't know why but it is very annoying.
I do take a look every few days but it is obviously not quite enough!
Have only looked at the problem for a few minutes but I believe that it is due to some changes that Litchi have made to the javascript in their Mission Hub.
I will investigate further over the weekend when I have more time.
N
N
Thank you very much!
We look forward to your reply and solution!
The program is wonderful and being without it made us sad !
I repeat here that if you can contribute to this project with some small financial support, I would be happy to help if you are interested !
Congratulations once again to the developers !!
The latest version with more the inclusion of grid and orbit WAS PERFECT !!
Note:
To summarize and facilitate:
Dedicated button send mission to google earth stopped working.
Grid creation button has stopped working.
Orbit creation button, stopped working.
Hello,
A different problem here. I was using VLM 2.5.0 to my great satisfaction but this morning I get this message :
Thus I uninstalled this version and installed the latest one (2.7.3). Same thing.
If I click "Continue" VLM opens like this, with an obvious US time (I'm in France) :
Help, #Namirda !
Hello,
Help, #Namirda !
I took the test and it just happened to me too !!!
Now got worse! It doesn't even open anything !!!
Error details (in Portuguese):
Consulte o final desta mensagem para obter detalhes sobre como chamar a
depuração just-in-time (JIT) em vez desta caixa de diálogo.
************** Texto de Exceção **************
System.NullReferenceException: Referência de objeto não definida para uma instância de um objeto.
em Virtual_Litchi_Mission.VLMServer.Check_Server()
em Virtual_Litchi_Mission.Form1.Form1_Load(Object sender, EventArgs e)
em System.EventHandler.Invoke(Object sender, EventArgs e)
em System.Windows.Forms.Form.OnLoad(EventArgs e)
em System.Windows.Forms.Form.OnCreateControl()
em System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
em System.Windows.Forms.Control.CreateControl()
em System.Windows.Forms.Control.WmShowWindow(Message& m)
em System.Windows.Forms.Control.WndProc(Message& m)
em System.Windows.Forms.Form.WmShowWindow(Message& m)
em System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblies Carregados **************
mscorlib
Versão do Assembly: 4.0.0.0
Versão do Win32: 4.8.4515.0 built by: NET48REL1LAST_C
Base de Código: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Versão do Assembly: 2.7.3.0
Versão do Win32: 2.7.3.0
Base de Código: file:///C:/Program%20Files/Namirda/Virtual%20Litchi%20Mission/Virtual%20Litchi%20Mission.exe
Microsoft.VisualBasic
Versão do Assembly: 10.0.0.0
Versão do Win32: 14.8.4084.0 built by: NET48REL1
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Versão do Win32: 4.8.4536.0 built by: NET48REL1LAST_C
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Versão do Win32: 4.8.4579.0 built by: NET48REL1LAST_C
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Versão do Win32: 4.8.4550.0 built by: NET48REL1LAST_C
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Versão do Win32: 4.8.4390.0 built by: NET48REL1LAST_C
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Versão do Win32: 4.8.4190.0 built by: NET48REL1LAST_B
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Versão do Win32: 4.8.4084.0 built by: NET48REL1
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
CefSharp.WinForms
Versão do Assembly: 99.2.90.0
Versão do Win32: 99.2.90.0
Base de Código: file:///C:/Program%20Files/Namirda/Virtual%20Litchi%20Mission/CefSharp.WinForms.DLL
CefSharp
Base de Código: file:///C:/Program%20Files/Namirda/Virtual%20Litchi%20Mission/CefSharp.DLL
Microsoft.VisualBasic.resources
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic.resources/v4.0_10.0.0.0_pt-BR_b03f5f7f11d50a3a/Microsoft.VisualBasic.resources.dll
Newtonsoft.Json
Versão do Assembly: 13.0.0.0
Versão do Win32: 13.0.1.25517
Base de Código: file:///C:/Program%20Files/Namirda/Virtual%20Litchi%20Mission/Newtonsoft.Json.DLL
System.Numerics
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
mscorlib.resources
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_pt-BR_b77a5c561934e089/mscorlib.resources.dll
System.Windows.Forms.resources
Base de Código: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_pt-BR_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Depuração JIT **************
Para habilitar a depuração just-in-time (JIT), o arquivo .config deste
aplicativo ou computador (machine.config) deve ter o valor
jitDebugging definido na seção system.windows.forms.
O aplicativo também deve ser compilado com a depuração
habilitada.
Por exemplo:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando a depuração JIT está habilitada, qualquer exceção sem tratamento
será enviada ao depurador JIT registrado no computador,
em vez de ser tratada nesta caixa de diálogo.
VLM Version 2.8.0 is now available for download.
As usual the download link is in the first post of this thread.
Sorry for recent issues with VLM 2.7.3 - it failed suddenly due to changes made by Litchi to their Mission Hub.
Hopefully V2.8.0 will fix the problems for the time being. However, due to it's very nature, VLM will always be vulnerable to upstream changes from the Mission Hub or downstream changes to Google Earth.
Apart from the bug fixes, the only change in 2.8.0 is in the way software updates are handled
N
N
Dear Namirda, thank you very much !
Installed new version, tested and functional again !
Can't imagine how happy it makes us return the program running normally again!!
Thank you very much on behalf of all satisfied users !!!
Reactions: Tufargon
... as OzoneVibe I enjoy VLM functioning again, I gained more understanding of interworking VLM, Litchi hub & GE Pro.
Big thanks to
NAMIRDA!
Thank you so much !
Your app is an essential tool to me !
VLM Version 2.8.1 is now available for download.
No biggie - but had to log back into Litchi account after this update - never had to after previous updates.
So long since I've had to log in took me for ages to find my login info. 😂
Steve_Amerson
This is very odd! Both of these images were taken today, but the bottom screenshot was taken today using my old HP Laptop while the top screenshot was taken with my new Laptop a few minutes later. I was wondering what might be wrong with my settings but now I am wondering why a Google Earth bug would only affect one computer and not the other. Both computers are using the same version of G.E. which is 7.3.6.9326 64 bit. This post was originally shown in the Litchi Forum with other users that were having the same problem. Mission Export as VLM to View Flight in Google Earth Pro Bug
Screenshot (2)
Screenshot (2)1920×1080 329 KB
Screenshot (13)
Screenshot (13)1600×900 282 KB
Steve_Amerson
Screenshot (2)
Screenshot (13)
This is almost certainly because you have the wrong FOV loaded.
You can see how to change that in this video :
Steve_Amerson
Screenshot (2)
Screenshot (13)
I have both computers set at Custom FOV of 85 so it doesn't seem to be that. Other Litchi users were reporting identical issues on the same day Jan 1, which was unusual, and I don't remember reading about it from any of the earlier posts.
Try changing the FOV to one of the other values in that video (use the file linked to load them if you haven't already) then run it again. If it FOV doesn't change from the new value then the program you a using to export (there are several options) is not including the FOV in the file, so it remains whatever was set.
You can also try changing the angle of the view by holding the CTRL or Shift key and using your mouse to move the image around
ScoobyPitt
