Official Mavic Air Range Leaderboard!
Do windsurfers count as a mod?
Yes as they are not part of the stock set up. Better known as parabolic extenders. A couple of members have placed on the modded section of the board using them.
Reactions: Jack Daw
Just got my MA & once I hit the 5239ft or 1597m mark I turned. I think I’ll go back out in a bit for a longer run since I’m stock and think I can get that 2000m mark :0)
Are all the max runs from the home point to farthest out or the whole trip?
Hello Des,
Yes, the max range to get on the board is from home point to the farthest point before RTH. Keep pushing it and you may have a chance to place.
Good luck!:cool:
Hello Des,
Good luck!:cool:
@Long Ranger
I updated my last flight that was a little bit further in this post instead of posting again as I hit about 2334 meters
Gave it another go and got the weak knees syndrome right after getting that weak signal alarm followed by a loss of
RC & black screen so I turned back at about 1.45 miles!
Next will be a 1.75-2 Miles attempt
Ok gave it another go and got the weak knees syndrome right after seeing a weak signal alarm and delayed video feed so turned at around 1.42 miles! lol
Next will be a 2 Miles attempt for sure! ;)
Nice, You placed #20. Welcome to the Leaderboard!Thumbswayup
Reactions: DesJardins
Very good! That's how you do it! How was the flight? I bet you were loving that range! #18 you are!Thumbswayup
Flight was good with no screen drop outs, just a few blips of video delay but pretty clean! Battery was my limiting factor today in this location. Finding that perfect area is the key for sure
Yes, and I noticed you increased your altitude as well. Of course this is always helpful with range depending on your location with interference and obstructions.
How about 10122 feet in a Mavic Air? Just seen this and wondering if that’s still a competitive number. I can get it from DJI go4 app and post that if it is.
I could of actually kept going. Just got nervous about battery power. I went a mile one day and 2 days later went for the 2 miles.
Yup, on my 2 mile run I landed just at 20% battery which was too close for my comfort as I could have kept going in that area as well! I’m glad I turned back after seeing the 2 mile mark reached
Reactions: Drone062074
Definitely a rush man and almost exact same on battery left. I got nervous after realizing the wind picked up and not in the right direction on my way back but I love it and will keep trying to go further [emoji1360]
That would get you on the board, so post your SS.;) Should be 3085M. That qualifies for 19th.:D
Screenshot_20180727-001154.png Screenshot_20180727-001343.png Made a couple of range test flights yesterday. Takeoff from the roof of my residential building (24 meters). No mods, stock controller. 5.8 Ghz.
Consistently got 2.000+ meters which is awesome for such a heavy urban environment.
This is a heavily congested area with tall buildings and heavy WiFi interference in the middle of Caracas' east side.
By the way, the height of both flights is actually from homepoint, and not above ground, since the city skopes upward towards where I was flying. Also, there is no FAA height limit at 400 feet in Venezuela.
I recently got the Titan Control antenna and plan to install it sometime this weekend. Will post data.
@Long Ranger
Here is my first entry for the Mavic Air. All stock and near perfect environment. Desert landscape (valley), no trees and very little signal interference. Signal was strong all the way out. I just took it out for a spin to see what it would do before the RTH kicked in and when it did I just let it come on back to test the RTH (landed the exact same spot it took off). Came back with 22% still left in the tank, strolled out at 18mph and came back at 28mph.
Went back out and got a little farther but this time RTH kicked in so this is my max at that location. Landed with 34% battery so could have pushed a little farther if signal would have permitted @Long Ranger
Location: Near perfect, pretty flat desert landscape. Mountains to the left are about 1/8th-1/4 mile away
11,090 Ft / 3,380 Meters / 2.1 Miles
Reactions: Drone Master
Nice,, like the new entries.:cool: Make note @beanbubba. If you are ready for it. New MP2 soon to launch. Hope your ready to run a MP2 Range Leaderboard..:cool:
OldGitRay
