My amp/antenna build and distance test (I will update thread as i go)
That tracking system you recommend doesn't work with the mavic, different receiver or something they just got back to me.
15 dbi ant. amp. That's what I'm waiting to see.
I hope it works better with amps then it did with the antenna by itself
ok :( did you look in that RC group link I posted a couple of pages back?
From what I'm seeing trees and your hills are going to hurt you without more altitude.
yup I wont be able to drop down as much or if at all :(
No I haven't yet, but I noticed it helps even with ant. is to keep it pointed best you can at bird like a panel.
ok good to know! I will do that I hope my panels come in early next week :)
I'm watching you before I get some, if it helps you I'll get a different pair of 20dbi and put on the roof.
yes that would be great if you can do that! :)
Flew Total of 45 miles today, 4.5 miles out under 200 foot, that's with ant. Did you get out droneuser??
that's pretty good!!! it will be a good test for me with all the trees and hills I have around here!!! no it was to cold and windy today :(
I'm guessing your ant. will do better than anything. You won't have the altitude for the panels, hope I'm wrong.
my ant? you means amps? or my 15 dbi ant?
also it sounds like titan amps are 3 watts just a fyi
I hope it does good!!! I will do a test with amps with 6dbi, 9dbi, 15dbi and panels when they come in I will post data :)
I know that 15 dbi antenna wasn't much better then srtock without amps :(
Dragsen
